Enhanced Wallpaper
New forum just for customizing your Acer Aspire One, desktop, wallpaper, icons, overall look, search bar.
Enhanced Wallpaper
Postby dandesigns » Tue Aug 19, 2008 4:59 pm
for people asking about the blue wallpaper i used, here it is along with different colors.
on my 12th linpus reinstall. i had Ubuntu Netbook and XP, but nothing beats the fast-on/fast-off advantage of Linpus lite.
dandesigns
Re: Enhanced Wallpaper
Postby dandesigns » Tue Aug 19, 2008 5:00 pm
and another..
dandesigns
Postby hasfrochbuster » Mon Aug 25, 2008 6:04 pm
Many Thanks!!!
Using them now!!!
hasfrochbuster
Postby zero9046 » Wed Sep 03, 2008 1:55 am
i tried to unzip one of these to the usr/share and i can't get to it. when i go to file manager and input the location (usr/share...) a little red circle with a horizontal white line through it pops up and it wont take me to the location. I've already engaged the "advanced" mod, but how do i get it to prompt me for my root password or whatever so i can unzip the png (i think that is the right file type) to the file...any ideas?
thanks
zero9046
Postby robert4380 » Tue Sep 09, 2008 7:52 pm
I noticed two problem when using these wallpapers... the "settings" and "help" buttons on the main desktop are now very hard to see since their color is so dark. Is there a way to change these fonts so they're white or something that will stand out? Secondly, the search bar on the desktop still shows a little of the default gray wallpaper surrounding it. Is there any way to clear that up? Thanks!
robert4380
Postby MAECTPO » Wed Sep 10, 2008 8:09 am
Could you make an orange version of the wallpaper?
MAECTPO
Postby dandesigns » Fri Sep 12, 2008 10:12 pm
here you go. sorry if it took a while as I came from a vacation. I'm currently running on XP now so I haven't tested this on A1 Linpus. let me know if it fits.
regarding the search bar, I use this wallpaper without it (disabled) as i don't use it often.
for the help and settings button, i edited their .desktop files and removed the name so it will only show icons and change the icons into something else. i might be posting some png's that could work for different colors but i cannot promise a specific date when (sorry).
here's how mine looks:
preview
dandesigns
Postby dandesigns » Fri Sep 12, 2008 10:16 pm
zero9046 wrote:i tried to unzip one of these to the usr/share and i can't get to it. when i go to file manager and input the location (usr/share...) a little red circle with a horizontal white line through it pops up and it wont take me to the location. I've already engaged the "advanced" mod, but how do i get it to prompt me for my root password or whatever so i can unzip the png (i think that is the right file type) to the file...any ideas?
thanks
you don't have to unzip these. just save them in any folder on your SSD (or SD expansion, eg. My pictures) then right click > settings > desktop (if i remember it correctly) then locate the file.
dandesigns
Postby dandesigns » Fri Sep 12, 2008 10:37 pm
here's a transparent png file for the search bar for people who find it useful. backup existing search_bar.desktop.png from /usr/share/search-bar/ and replace it with this one. i haven't tested this yet as i don't have the linpus installed on mine. let me know if it works.
dandesigns
Postby dandesigns » Sat Sep 13, 2008 12:05 am
i've decided to put the PSD file here so anybody can create their own color scheme (we're promoting Open source anyway.. :) )
download the PSD file @ mediafire: http://www.mediafire.com/?sharekey=84df ... 705bb6a8d4
dandesigns
Return to Desktop Customization
