Another solution for SSD: EWF?
Windows OS and software
Moderators: Ranjit, rory
Re: Another solution for SSD: EWF?
Postby zk2008 » Sat Aug 23, 2008 10:50 pm
Before I commit the time to do this mod, could someone please explain the reasons I might not want to do this mod? I'm assuming there are some.
Z
zk2008
Postby BrandonMB » Sun Aug 24, 2008 12:18 am
I enabled this mod using the scripts for the registry entry, and when I try entering ewfmgr c: I receive the following error:
Failed getting protected volume configuration with error 1.
Incorrect function
I have confirmed that my disk(0), etc information is correct, and googling hasn't helped much. I am still able to write to my SSD. If anyone can assist, it would be greatly appreciated.
BrandonMB
Postby dean » Sun Aug 24, 2008 1:31 pm
BrandonMB wrote:I enabled this mod using the scripts for the registry entry, and when I try entering ewfmgr c: I receive the following error:
Incorrect function
Brandon, try Idq steps in the earlier posts... :D ...it shud work.. :D
dean
Postby MiniM3 » Sun Aug 24, 2008 8:43 pm
zk2008 wrote:Before I commit the time to do this mod, could someone please explain the reasons I might not want to do this mod? I'm assuming there are some.
Z
zk2008, it's worth it, speed is ridiculously fast, but downfall is that if you install or setup something in windows, you need to run the commit script so that it saves for next session. Other then this, Windows is blazingly fast.
MiniM3
Postby daymz » Mon Aug 25, 2008 1:06 pm
Incorrect function
I was getting the exact same error when I tried it out too.
And I did follow the steps from this thread. No idea what the problem may be, the error message is a bit cryptic and uninformative, hehehe.
daymz
Postby BrandonMB » Mon Aug 25, 2008 1:10 pm
Ok, figured it out. The .reg files that are posted do not work 100%. You have to go through the registry entries and edit them manually. Once entered properly, it works just fine, and the speed boost is absolutely unreal. Simply go through iDq's steps one by one in your registry, and it's beutiful.
BrandonMB
Postby dean » Mon Aug 25, 2008 2:37 pm
BrandonMB wrote:Ok, figured it out. The .reg files that are posted do not work 100%. You have to go through the registry entries and edit them manually. Once entered properly, it works just fine, and the speed boost is absolutely unreal. Simply go through iDq's steps one by one in your registry, and it's beutiful.
...good for you...and now enjoy yr AAO... :D :D :D :D
dean
Postby jdetmold » Mon Aug 25, 2008 7:24 pm
this worked great for me! the speed is amazing
after geting everything setup i followed this guide to make my sd card a local disk
http://www.lancelhoff.com/2008/06/19/ma ... ocal-disk/
then i used TweakUI to move my documents, desktop and favorites folders to my sd card i can now save files make folders and add favorites without the need to commit the changes.
jdetmold
Postby jzx » Mon Aug 25, 2008 10:58 pm
For anyone still having trouble with the registry editing, I just used the whole thing from the blog post and it works instantly :)
EDIT: EWF plays nice with Truecrypt too! Yay :D How freaking cool is that 0b?!?!
jzx
Postby rocklord » Tue Aug 26, 2008 7:21 pm
Would EWF work if you installed a ZIF HDD or CF in your AA1, or on a 120GB model? The ATTO disk benchmark for EWF installed on the SSD posted previously was a write speed of over 600MB/sec, whereas a ZIF drive and the Transcend 300x CF write speeds were only 34MB/sec.
Comments?
Owner of an AA1 since 22 August 2008.
Upgraded w/ 80GB Hitachi HDD, 1.5GB RAM, 1390 Dell WiFi
WinXP/OSX iATKOS 4i Dual Boot
2Ghz CoreDuo, 2GB, Hackintosh w/ Kalyway 10.5.3
2.13Ghz Core2Duo, 2GB, Homebuilt PC w/ WinXP SP3/OSX Kalyway 10.5.3 Dual Boot
1.25GZ G4, 1GB, Mac Mini OSX 10.4.11
rocklord
Return to Software - Windows
