Another solution for SSD: EWF?
Windows OS and software
Moderators: Ranjit, rory
Re: Another solution for SSD: EWF?
Postby cylo » Thu Aug 14, 2008 7:39 pm
MiniM3 wrote: Is there a way to write all these registry entries into one batch file and run it so that I don't have to enter every entry one by one?
Thanks in advance!
Damen
Here's my try... hope its usefull
name it ewf-enabled.reg
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_EWF]
"NextInstance"=dword:00000001
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_EWF\0000]
"Service"="EWF"
"Legacy"=dword:00000001
"ConfigFlags"=dword:00000020
"Class"="LegacyDriver"
"ClassGUID"="{8ECC055D-047F-11D1-A537-0000F8753ED1}"
"DeviceDesc"="EWF"
"Capabilities"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\R oot\LEGACY_EWF\0000\Control]
"ActiveService"="EWF"
name it ewf-device.reg
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ewf\Parameters]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ewf\Parameters\Protected]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ewf\Parameters\Protected\Volume0]
"VolumeID"="{1EA414D1-6760-4625-8CBE-4F9F85A48E15}"
"Type"=dword:00000001
"ArcName"="multi(0)disk(0)rdisk(0)partition(1)"
Please do take care with ArcName, adjust it with your configuration
here, i also make it as a package :)
After you installed all that things above, restart your AA1 and hit awfmgr c: on command prompt
Thats all.
I'm also want to make a question does it really necessary to include VolumeID on that Volume0 Key..? :D
enabling-EWF.rar
Enabling EWF on Aspire One,
thanks for aspireoneuser.com and SFiorito@Mp3Car.com
(170.8 KiB) Downloaded 951 times
cylo
Postby Grella » Sun Aug 17, 2008 12:51 am
Hi everyone,
I've modified Group Policies
At Startup, added a .bat script with
ewfmgr c: -enable
At Shutdown added
ewfmgr c: -commitanddisable -live
ewfmgr c: -enable
With this, all modifications are commited at shutdown, e.g. settings / configs
You can access GP by gpedit.msc command
More info at: http://forums.techguy.org/software-development/548398-how-run-command-before-shutdown.html
*EDT: You need to do it with ewf disabled, since it modifies the protected partition/disk
Grella
Postby oscar » Sun Aug 17, 2008 2:39 am
Hey there all, firstly, thanks for guide. Works great.
I still only have 512mb ram but the diff from b4 is amazing.
First I tried eeepc v.2 xp, very responsive, only 85mb ram usage with all drivers but msn msngr wouldn't work,
and httctrl.ocx error on every boot.
Then tinyxp v09, very complete but very slow. Ram usage at 160mb. No errors so far.
With this trick you have performed the AA1 is lightning fast, actually it's more responsive than my big pentium desktop.
Thanx !!!!
8GB SSD (TinyXP + CrunchBang) Mods: 250 SATA (XP MCE +Se7en + Ubuntu) - bluetooth - 1.5gb ram - 16gb class6 sd - added heatsinks all done @ www.cybertekspain.com
oscar
Postby myst » Sun Aug 17, 2008 7:25 am
thank you so much! my a1 is re-born today.... it's blazing FAST! kudos also for Grella Scripts, it's a cool solution!
p.s.
thanks cylo for the RAR, but there's something wrong in your .reg... i had to manually enter the keys from the first post to make it work right.
myst
Postby iDq » Sun Aug 17, 2008 10:28 am
Grella wrote:[...]
ewfmgr c: -enable
This is not needed ;). EWF will start automatically unless you execute: ewfmgr c: -disable.
iDq
Postby twizzo » Sun Aug 17, 2008 1:51 pm
Hey Grella any chance you can upload the .bat script for shutdown.
thanks
twizzo
Postby iDq » Sun Aug 17, 2008 2:13 pm
twizzo wrote:Hey Grella any chance you can upload the .bat script for shutdown.
thanks
Here is...
commit.zip
(163 Bytes) Downloaded 356 times
iDq
Postby iDq » Sun Aug 17, 2008 2:20 pm
myst wrote:thank you so much! my a1 is re-born today.... it's blazing FAST! kudos also for Grella Scripts, it's a cool solution!
p.s.
The error is here:
cylo wrote:Windows Registry Editor Version 5.00
"Service"="EWF"
"DeviceDesc"="EWF"
It should be: Root
iDq
Postby twizzo » Mon Aug 18, 2008 1:08 am
can anyone upload a working ewf-enabled.reg file i tried fixing the error in cyclo's file but all i get is an error saying cannot import cannot access the registry, is there something i am not doing or doing wrong here?
twizzo
Postby dean » Mon Aug 18, 2008 9:32 am
twizzo wrote:can anyone upload a working ewf-enabled.reg file i tried fixing the error in cyclo's file but all i get is an error saying cannot import cannot access the registry, is there something i am not doing or doing wrong here?
Twizzo, tis happened to me earlier..., try tis
# Before you merge it you need to alter the permissions on one registry key. In regedit, navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root.
# Right-click on Root and click ‘Permissions’. Set ‘Everyone’ to have Full Control and then merge the file by double-clicking on it, ensure that all values were entered properly and then reset the Root key permissions to the way they were before.
Quoting from a blog in the earlier post... :)
dean
Return to Software - Windows
